Indeed, my digital says M3x3, ebay got it
If you can borrow a set of hex drivers from a friend that will establish the size; RC drivers use them. The one on my printer is either 2.0mm or 1.5mm, 2.0mm I think
It is indeed an M3 x 3mm, I ordered some from Ali in China some time ago for spares, make sure you order ones with a flat end not a point. The first ones I ordered had a tapered point and they do not work that well so I had to file the end to get better grip on the rod from the stepper motor.
The smallest of the three hex keys supplied with the UM2 fits, 1.5mm I think
gr5 2,070
You mean on your feeder? The screw just left of this arrow head?
I don't know the answer but everything Ultimaker seems to be metric so probably 3mm or maybe 2.5 or 2mm. Probably 3mm.
