Gotcha! Any way to estimate how much of the filesize is attributable to parts of the model? Or is it anyone's guess?
It is the "percentage of the GCode printed"Actually the percentage of the file size printed so far. So if the file is 2MB and and you have printed 512K, it will say 25%
Are you sure about that?
To me, it has always seemed like it read out current layer / total layers in percent.
Read the code...
Marlin doesn't know anything about layers...
The GCode file contains layer information. Marlin would "simply" need to read through the full gcode file before starting the print, in order to find the amount of layers.
Then, it would have to read the "layer: xx" information instead of just skipping it (because it's a comment line).
It's not as easy as in "you can write that code in 5 minutes" (programming always takes it's time..), but should be doable without problems.
Not as simple as that...
"# Layer xx" is as you say a comment, it is what Cura does, but there is no guarantee that it will be there if you are using another slicer. So you have to look at the Z movements to make up you mind.
And also, layer is not necessarily a good representation of time, depending on the complexity. Some layers take much more time...
So after all, looking at the percentage of GCode actually printed is definitely not a bad option and in my view much better than number of layers.
Agreed. I didn't ever think that was a good idea. I've never found the percentage displayed to be exceedingly accurate though. Especially when a print starts large and narrows at the top.
amedee 340
