yellowshark 153
I assume that as the retainer will be placed in the mouth you will need to use a material that is certified by your medical authority. I do not know if such a material exists that can be used by the UM or other similar FDM printers. If not done so already, it is probably worthwhile establishing that before going too much further.
ultiarjan 1,219
The easy route is to find a 3D hubs in your area, many UM2 users on there.
https://www.3dhubs.com/
I would advice in your case to also have a look at & order a testprint from a DLP printer user (like f.e. the Atum... http://www.dlpprinters.com/)
