Dim3nsioneer 557
You may check:
- if the screw holding the bearing at Robert's feeder is fully and properly in
- the nurled bolt is clean
You may check:
swordriff 119
Maybe clogged nozzle? Try Atomic Method 2-10 times,,to clean out the
nozzle. Use a different, but light color PLA so you can see what sticks to it:
Not much beats this (@iroberti
http://support.3dverkstan.se/article/10-the
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
