re invert x and y axis to original state
matthew22
Posted · re invert x and y axis to original state
hey everyone i bought a Ultimaker with inverted axis a while ago but it doesn't fit where i want to put it because the steppers are sticking out and i have put it back to original form on the inside of the case but that reversed the way it moves and was wondering how to put it back? :)
    If it's just a question of the orientation of the motors (no direct drive), uploading the newest firmware with Cura will solve your 'issue'...
    If it's just a question of the orientation of the motors (no direct drive),uploading the newest firmware with Cura will solve your 'issue'...
    the thing is I have used costem marlin hex builder to make firmware beacuse I have a DIY heated bed so I think I will try build another one and see what I can do thanks for reminding me haha
    If you want a easy firmware creator (just in case you plan to change something in the future), you could try the @Amedee firmware generator, I works like a charm
    https://bultimaker.bulles.eu
    dose it work with a DIY heated bed beacuse normal software dosnt I don't think
    I used this http://marlinbuilder.robotfuzz.com/
    i figured it out guys thanks heaps for all your help :)
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 10 replies
