HIIn Cura you need to go to expert, full settings, then go to the advanced tab and you will see infill speed. Slow this down. 10mm/s (or close to it) above the print speed is good. to fast and you get problems like yours.
you can even out all the speeds so they don't vary to much between each other.
Example:
50mm/s outer shell
55mm/s inner shell
60mm/s infill
50mm/s top bottom
This is what I thought I would be able to do. Is there no other way to compensate for more flow? After exploring the settings the speed only seemed to be around 100ish mm/s so the printer should definitely be able to handle that, no?
Labern 774
HI
Example:
50mm/s outer shell
55mm/s inner shell
60mm/s infill
50mm/s top bottom
