So how can I known which part is loose?
If the belt is loose, I don't think it can be tightened after printing.
Thanks.
Thanks.
There are guides under the support section of the main Ultimaker website.
Here is the link to the issue you have: http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#leaning
Its a very good guide with pictures that show exactly what to look for or adjust.
Thanks, @labern
I'm trying to fix this problem according your link.
And will give feedback after testing.
Another thing I want to mention here is that the screws of UM2 are really low-quality.
It's easy to slip when using hex wrenches (the edges are scuffed), and I'm doubting whether the screws are able to loose again.
Yes I agree that you need to be careful with the screws
The screws are not that bad but the allen keys that they supplied are low quality. dome head screws tend to strip easily as the hexagon hole isn't very deep so care needs to be taken.
Nice to see you online.
I have tried to open the extruder, but failed due to three of the four screws stripping.
Maybe need to buy some good ones to replace original ones, but don't know where to buy:angry:
Yeah I grabbed a few spares from work
there should be a good fastener store in your area
Try using a Torx-driver instead, it grabs the screws fairly tightly even if they have been damaged.
Thanks, I will try this.
Wow that's a nice print. Glad it's all going good now. You will be pleased
danilius 117
This looks like a mechanical issue. You have something loose, and it get tightened after printing once, then probably loosens again afterwards.
