raising off the bed
Are you talking about edges of parts that lift off the bed later? When you are printing upper layers? This happens a lot because as the upper plastic layers shrink it pulls hard inward and lifts the lower corners. There are many great and easy fixes to overcome this problem.
gr5 2,334
Did you watch it happen? that blob on top of your bottom layer looks like it was created when you started the print - the printer prints out some filament to get things started and sometimes it kind of sticks to the nozzle and then gets dragged around with the nozzle for a while until it eventually falls off and then later maybe the head hits it again and pushes it somewhere else.
I always run over to the printer when I hear it starting and grab the initial filament and pull it - pulling extra fast as it moves to the start of the print (to make a thinner-than-thread, easily broken, safe strand).
