You have pillowing and bad stringing. Make sure your fans are on 100%. You maybe able to print a bit colder.
- 1
You need to include a picture of the basic page.If you remove the floor section under the stairs the the infill will support them. It also looks like you need to increase the top/bottom thickness. 6-8 times the layer height.
Hi labern, The top and bottom thickness are .8 The fans are on 100%
It looks like you may be right about the T/B thickness, I am doing another print with a thickness of 1.2mm and the quality is a lot better, but I didn't add the stair (unfortunately). I will print that later and if it comes out ok I'll just drop it into place.
Old vs New huge improvement...
Edited by GuestDefinitely Looks a lot better.
I found that for really superb top layers the infill at 26% changes it's pattern and makes for a 'less holes' pattern that covers really sweet. On cura ofc.
I normally use 10% infill. If everything is set right then it should fill it in just fine.
Labern 774
Edited by GuestLink to post
