couple seconds and then skip back about 120 degrees pulling the filament back too
This has many names - such as "feeder skips". It's by design. The current sent to the feeder is purposely reduced such that it will skip back before hopefully before grinding the filament. On the UMO it tends to grind the filament.
As a result you get gaps for several seconds where it's not printing much.
The normal fix, for a working printer, is to print a bit slower or a bit thinner layers or a bit hotter. Although it's possible your printer is defective. In general this issue is called underextrusion. Anyway if you have the nozzle hotter, the plastic is less viscous and you can pass more volume of plastic through the tiny nozzle. At lower temperatures you can pass less. It's not recommended to go over 240C for PLA.
Here are top recommended speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion.
1
DidierKlein 729
There are two different behaviours with the feeder:
1. The feeder skips a step, you will hear a "tick" sound, the filament isn't pulled back, this happens when for a reason or another the feeder can't push the filament as it should. This prevents the feeder from grinding the filament. It can happen for multiple reasons: partially clogged nozzle, bad filament (too wide), worn out teflon, bad print settings (too cold, too fast).
2. The feeder pulls the filament back, no tick sound is heard, this is due to retractions, they happen on purpose to prevent the nozzle from oozing and dripping on the print.
What it the behaviour you're experiencing?
