4,297 -
33
Posts posted by Dim3nsioneer
Is it loaded or not?
I miss the logic here. Spiralize is a concept that asks for a single object to be printed. Layer height, independent of being fixed or adaptive has to be the same for all objects on the build plate. And that is how the Cura setting works.
Not every PETG is the same. Ultimaker PETG works pretty well with PVA, others might not work at all. Aquasys 120 certainly offers a wider range, but also BVOH might be worth to have a look at with PETG.
No, it will not work without a hack for providing power and on/off logic since both the 2+ and the 3 lack of the needed connector.
The maintenance menu in the systems section gives you access to 'about this printer' which tells you the amount of time a printcore has run independent of the machine it was in.
Now I'm curious. What material do you print that you need Kapton tape on your S5 instead of any standard adhesion agent like glue stick, Magigoo, 3DLac, Printafix etc.?
I think this happens if the installation is started from a non-admin user. I have it too.
Why exactly do you need the print job to finish at the time you arrive (compared to having finished earlier - e.g. by starting it in the evening before, maybe remotely through Digital Factory)?
Wenn Englisch keine unüberwindbare Hürde darstellt, würde ich die zweite Ausgabe von Ultimakers Webinar-Reihe "The Additive Chef" von dieser Woche empfehlen: Darin geht es um das Drucken von Miniaturen mit Cura 5.0. Mariska von Ultimaker gibt darin etliche Tipps, wie man auf einem Ultimaker Drucker Ergebnisse erzielen kann, die zwar sicher nicht einen Harzdrucker schlagen oder egalisieren, aber doch für FFF sehr ansprechend sind.
Link: https://ultimaker.com/learn/printing-small-parts-and-fine-details-webinar
- 2
Depending on the material it can also be used for the periodic print core cleaning (light PLA).
Because it is caused by an issue of the printer?
15 hours ago, Nosybottle said:
I guess I could contact our reseller who provides support, but as it is I don't really have much to tell them.
Logfiles might help as they could contain a hint why it is driving to a wrong location. The quicker you download them after it happened, the better.
If you guys suspect the firmware doing something strange suddenly, try a Digital Factory Reset. It does reset the Digital Factory (so you would have to reconnect the printer, sorry) but it seems also to act as some kind of soft reset for the firmware.
Check the detailed settings for "minimum wall line width".
Do you hear a sound if you click the button? If yes, then it's just the display.
If not (what the missing LAN connection suggests), then it might be an Olimex issue. You will find tons of information here: gr5.org/unbricking
I usually put prints that don't want to come off without force together with the glass plate they are stock onto into the freezer. That works pretty well as long as no combination with water soluble support material and strong adhesion agent is involved.
I think you indeed do not need a raft with ASA or ABS if you use the glue stick as adhesion agent (smeared to a thin film with a wet cloth!).
Please feel free to implement this by issuing a pull request on Github since Cura is open source.
The front fan should run if at least one printcore is above 40-50 degC. If it doesn't and it is connected at the right place on the print head pcb, that pcb might have been damaged by the head flooding. In that case you best get in contact with your reseller.
- 2
Changing the e-steps should not be necessary on an UM3. Maybe you want to check your axles for play - that is what usually causes one axis to deviate more than the other from the default value.
See https://support.ultimaker.com/hc/en-us/articles/360011490220-Check-for-play-on-the-axles-of-the-Ultimaker-3. -
Works fine for me with a S5 in 4.13.1 (with a deformed model of a cube as modifier mesh). Has any of you guys already tried to clear the Cura installation (deleting/renaming settings folder)?
10 hours ago, gr5 said:
Does gcode pausing work on S5? I can't remember which printers it works and which it does not. Well I'm pretty sure it works on the UM2.
It works on the Ultimaker s-line printers but not yet on the 2+ Connect afaik.
Rewind that material onto a compatible spool or buy a material which the spool of it fits into the Material Station?
Here you find the required spool dimensions: https://support.ultimaker.com/hc/en-us/articles/360012904539-Spool-dimension-compatibility-in-Material-Station
Maybe you still have a printjob with that material in your print queue?
Sync materials from Ultimaker printer back to Cura
in UltiMaker Cura
This is not possible. But logging in with an Ultimaker account from Cura and using Cura backup should do the trick.
