4,297 -
33
Posts posted by Dim3nsioneer
On 4/1/2021 at 8:08 PM, kermitas said:
What is the easiest, confirmed-that-working way to upload filament's profile and then being able to select it on S5's screen?
That would be to connect printer and PC with a direct Ethernet connection and make sure the firewall on the printer is disabled.
Any direct network connection (not through the cloud) works for that purpose.
I would assume BASF will bring such a filament if it is possible to print and post-process it.
Wouldn't do a reduction of the flow have the same effect?
And no, I don't see that effect on my Pro Bundle unless the first layer flow setting is crap for the profile used.
What would be the use case for such a feature?
Genau. Man kann natürlich anstatt des Support-Blocker-Würfel auch ein anderes, geladenes 3D-Objekt als Modifier Mesh verwenden.
On 2/16/2021 at 8:35 PM, gr5 said:
Your reseller can look that up. In other words if you bought this used then find a big reseller in your area (maybe igo3d?) and email them with the serial number. It may still be under warranty.
The distributors and resellers do not have access to the production documentation of an individual printer at Ultimaker.
Distributors know through which reseller a printer was sold and can forward an inquiry.
Please be aware that often warranty applies only to the original owner and is not passed on when a printer is sold.
What adhesion agent do you use? In case you use the glue stick and it is not enough you might want to try e.g. Magigoo Original for ABS and Magigoo PC for polycarbonate. Be aware the first one can adhere extremely well, depending on the filament brand.
If you still have the old white piece that grips the Bowden tube simply tak that one.
If you want to use a material the profile of which does not support the Material Station, you have to use a generic profile such as the PA GFF in this case. Be aware that it is not uncommon that this way fails at unloading the material.
Personally, I usually switch the printer off, disconnect the Material Station for such materials and put the spool holder back in, then reboot the printer so it starts as a standalone S5.Of course it does not hurt (hopefully) if you contact the manufacturer and ask if making the profile compatible with the Material Station is planned.
Sink it into the buildplate is even possible with the "drop to buildplate" option enabled. You should disable that option if you want an object "hovering" over the plate, i.e. creating a vertical space that will be filled with support structure. When you "unsink" the object, the "drop to buildplate" comes in handy again.
Your reseller should be able to answer that question... 😉
Yes, it is. 🙂
Should be possible. The two materials are definitively compatible. An issue could be stringing of the TPU.
The heatbed pcb including a 4-wire cable is available from a well sorted reseller (i.e. a preferred reseller as Ultimaker calls them).
Ultimaker or third party material?
Did you try to unload it, remove the spool (important!) and reload it?
Put Ultimaker material to the left edge of a bay.
Your Cura installation and the printer must have a direct network connection, so the firewall has to be disabled. Then Cura sends materials unknown by the printer to the printer at startup of Cura.
As Aquasys120 does usually stick pretty well to Ultimaker PC, I think the issues in your case come from the support generated by Cura. They seem to be very small and fragile. I suggest you increase the supports a bit by using the join distance and horizontal expansion options in the support section of Cura.
If a Pro Bundle was stuck on the Ultimaker screen, it has been a good strategy in the past to restart the Pro Bundle without the Material Station being connected, i.e. as standalone S5 and then perform a reset of the printer settings in that state before reconnecting the Material Station.
10 minutes ago, gr5 said:
But you should contact your reseller immediately. I strongly suspect every reseller has seen every possible problem including this one. I don't have the Material Station - just the plain S5. But I've heard many people ask questions in this vein and the answer is very often: talk to your reseller.
That is a very good advice. The reseller is always first choice to ask warranty questions. I cannot speak for other resellers or Ultimaker in terms of warranty. I can only refer to the warranty document by Ultimaker: https://support.ultimaker.com/hc/en-us/articles/360011627400-Ultimaker-S-line-warranty
Does the grinding happen right from the start of a print or later?
44 minutes ago, Nico04 said:
1. I've added a Ziflex on the plate, but unfortunately I can't use my printer anymore because the calibration is only physical (using screws) and I've reach the end before teh right settings.
Wow, how thick is that plate that pulling the bed down is not sufficient?
@gr5 already gave the spot-on explanation for no. 2.
46 minutes ago, Nico04 said:3. The feature "Skip cooldown" introduces some bugs : If I change the material, then skip cooldown, and immediately start a print, it will hang forever on the "preparing" screen.
Sounds like a bug. Please report it to your reseller so it can be passed on.
47 minutes ago, Nico04 said:4. How can I change settings while printing, like the printing speed ?
I'm away from my UM2+ Connect atm, so can't check it. If there is no tune menu there yet, I imagine there will be and it will be more populated in future.
48 minutes ago, Nico04 said:5. I'd like to use my printer on my local network, without internet, how can I do that ?
You can't and you will never been able to. It was advertized to be cloud-based right from the start.
49 minutes ago, Nico04 said:6. The open WiFi of the printer is always on, even after it's connected to my network, how can I disabled it ?
You have the printer connected through Ethernet and it still has a WiFi enabled? That would sound like a bug too you might want to report through your reseller.
Sorry to be a bit persistent: Does the same print core also still work with other materials after you printed the I180 with?
As for the print core cleaning: did you use hot pulls or cold pulls? In case you used cold pulls: did you get a perfect mirror image of the inner print core geometry on the pulled filament? -
Does the same print core work with a different filament and does the I180 work in the other print core?
You can always manually arrange models in the build plate with the translation/move tool.
If your model stays in the aur, please check if you have "drop models to build plate" enabled in the Cura configuration settings.
Also, model errors can affect Cura's ability to arrange objects on the build plate.
Was für ein Material druckst Du denn, bei welcher Temperatur und hast Du das Druckbett auf dem UM2+ sauber manuell ausnivelliert?
Upload custom filament profile from Cura to S5+Material Station
in Materials & profiles
It submits the data automatically after establishing the link and on each Cura startup.
