Object Too Tall
celso-santos
Posted (edited) · Object Too Tall
And sometimes even though the object is small enough for 'one at a time' it can be better to print f.e. 2 small ultibot's at once so the layers get more time for cooling.
The default gantry hight of um2 is now 48mm (was 55 mm in the beginning) this will change f.e. when you install the Olsson block. It can be set in "machine settings" but be careful and measure your actual gantry hight if you change... set it to high and parts will get knocked over by the xy axis. To be save just leave it at 48mm.
