Filament not feeding UM2XT.
Could be that the Bowden tube on the feeder end is not all the way down into the receptable. This can make the filament crash into the end of the Tube and not entering it.
Reinsert the Tube by removing the horseshoe, press down the circular clip holder, and wiggle the tube until it falls into place, If I am right ca 5mm more than it is now, maybe?
Cut a piece of filament 10cm. Make it pointy at the entry end, and square flat in the back end. Straighten it as best as you can.
Try feeding that manually, wiggeling it to make it enter the hole inside.
If that works, then drag it out again and feed from spool. Here also help it by holding it vertical into the feeder.
Use in Advanced "Move Material" for all this.
gr5 2,097
Strange. Could it be the filament is too thick? Like 3.05mm? Instead of the typical 2.85mm?
So are you using the "change filament" procedure? Is the motor turning slowly as you feed it in? It should be. And push hard upwards - like 5 pounds force - enough to almost lift the printer up in the air.
