You want enough tension on the filament that you can see bite marks on it.
Next, if you are getting kick-back, you might have a clogged nozzle as @cloakfiend suggests, or the temperature of your material is too low, or your printing speed too fast. There is no set speed for PLA or any other material; each roll can and usually will be different and therefore you have to learn the extrusion volume/temperature/speed ratios all over again for every new roll you get.
cloakfiend 995
no need to mess with the screw, put it back to how it was, and just do atomic pulls properly and print off the roll and your problem will vanish.
atomic pulls:
printing off the roll:
your prints may look fine for a while if you dont do atomic pulls, but its only a matter of time before your prints suffer from a blocked nozzle or snagged filament. works for me everytime. Beeping is retraction that is something unrelated and it does that when its moving from one part to the other. sort out the annoying clicking first with atomic pulls and go from there.
Edited by GuestLink to post
