mark 0 Report post Posted September 8, 2012 in Printing Directly to Glass Hi All, While printing onto blue tape works fine I don't like needing to replace it whenever a print sticks to the bed super well and would prefer to be printing on a more consistently flat surface anyway. I've seen other people mention on the forums and elsewhere that they were successful at printing directly to non-heated glass, but they didn't mention what settings they used. With a few tests I've done today it seems to be sticking pretty well when using a temp of 205 but still has a problem with curling every once in a while. So now for my question: What success have others had at printing directly to cold glass with PLA, and what settings have you tried? And then for another possibly related question; all of a sudden today I started randomly having problems where bits of the ABS fix kit which I ran through a while ago block the nozzle for a short period of time and then come out in a glob, messing up the print. This is when printing at temps between 195 and 205, which I thought was too low for ABS to melt. Does anyone have a clue why that might be happening, and/or have any idea as to how to fix it? -Mark Share this post Link to post Share on other sites
joergen 1 Report post Posted September 8, 2012 in Printing Directly to Glass AFAIK, PLA will not stick to cold glass, and neither will ABS. The recommended glass surface temperature is very similar to the glass-transition temperature of the plastic you are using: PLA needs about 70C, and ABS 110-120C HBP glass temp. (In case you care, PLA Tg is 58C) Share this post Link to post Share on other sites
mark 0 Report post Posted September 8, 2012 in Printing Directly to Glass I understand that printing directly to glass isn't recommended, and that it isn't easy to get working, but I refuse to believe it impossible. For example I have successfully done it twice in a row today: It might not be entirely clear in the images above (pardon my poor camera) but there was little to no warping in the corners (the first layer was very sparse filament wise due to some residual ABS getting in the way). Granted this was a fairly small print which only took 30 minutes to print, but I think it shows that it is possible, at least for small prints. So far with my tests it seems that the print is more successful if there is slightly less filament being extruded than normal for the first few layers. My guess as to why this is is that when there is more filament extruded it's easier for it to stretch and curl up, but that's just speculation. I'm going to try adjusting the start gcode to get more consistent results (I think I'll start each print by retracting a small amount). For anyone interested my current settings in Cura printing PLA are as follows: Layer height: 0.2, Wall thickness: 0.6, Print speed: 75, printing temperature: 205, bottom/top thickness: 0.6, fill density: 25, bottom layer speed: 45, travel speed: 130 These settings aren't perfect yet but are consistently working. I have not sanded or done anything special to the platform. Hope this helps others get off their tape dependence someday -Mark Share this post Link to post Share on other sites
spooner777 0 Report post Posted September 19, 2012 in Printing Directly to Glass That print quality looks very good. What PLA do you use? Share this post Link to post Share on other sites
fluxline 0 Report post Posted September 19, 2012 in Printing Directly to Glass I have also printed directly to cold glass with PLA, both plain and frosted, with and without PVA glue. Really can't give conclusive results yet other than it works if the print is small, less than 30mm, with no curling/warping/popping off. Bigger and parameters such as PVA glue concentration, printing temperature/material(color, provider), can cause unexpected results. Unfortunately, I had to get on to real work with the printer and for now that means blue tape for the size I am printing. I actually have a new problem and that it is sticking too well to the tape and it needs replacing every time :( Share this post Link to post Share on other sites
mark 0 Report post Posted September 22, 2012 in Printing Directly to Glass At the moment I'm still using the PLA that came with my kit. I bought some UltiMachine PLA for when I run out but still have a little ways to go. I am having a similar issue with bigger prints not sticking correctly. When I saw the Replicator 2 videos (from MakerBot) my first thought was, "Hey that's a metal UltiMaker!" My second thought was, "Hey they're printing PLA onto a cold build platform without difficulty!" It looks like they have some laser engraving or sanding on their platform to help the PLA stick better. I'm trying to replicate their results by sanding my plate a little with mixed results. I can't tell if I need finer grain sandpaper, or if I haven't sanded enough, or what, but I'll keep trying and let you all know if I come up with something that works. -Mark Share this post Link to post Share on other sites
ronald 0 Report post Posted September 27, 2012 in Printing Directly to Glass Tried to print on glass, but PLA didn't stick to it. However when I used Hairspray on the glass, PLA kept sticking on it. Share this post Link to post Share on other sites
destroyer2012 0 Report post Posted September 28, 2012 in Printing Directly to Glass Hairspray is an amazing solution. I'm using it for printing with abs and i've sprayed it on top of kapton tape. So far I've printed four times on the hairspray with absolutely no loss in adhesion. Usually after the third time kapton tape starts to get weaker but not with the hair spray! I am tempted to try directly on aluminum without the kapton, considering your success with glass. Nice job! Share this post Link to post Share on other sites
futurejames 0 Report post Posted September 28, 2012 in Printing Directly to Glass Does the hairspray have any effect on the bottom layer? Does it change the appearance/texture/etc.? Share this post Link to post Share on other sites
ronald 0 Report post Posted September 28, 2012 in Printing Directly to Glass Tried to print on Metal but didn't stick even not with Hairspray. It made a big mess When I tried on glass with hairspray the bottom surface was a little rough but mostly shiny Also tried PVC but it melted (ofcource but tried it anyway) Got the information from Thingiverse: 28787 Share this post Link to post Share on other sites
mark 0 Report post Posted September 29, 2012 in Printing Directly to Glass Haven't tried hairspray yet but sounds interesting. So far I scuffed up the build platform with some 450 grit sandpaper and then smoothed it out a bit with some 120 grit sandpaper. I also increased my nozzle temp to 220 (not sure how much that helps but the Replicator 2 is using 230 as their default temp). The results so far have been pretty good: The klein bottle was printed using minimal raft. I've found that using a raft typically fixed the printing issues, but of course is a pain to clean up afterwards so I'm not calling it a solution . By slowing the first layer speed down to 30 mm/s it does seem to be sticking better. -Mark Share this post Link to post Share on other sites
snowygrouch 1 Report post Posted October 2, 2012 in Printing Directly to Glass Hi Mark, With respect to surface texture, you might want to consider just buying a cut plate of "frosted glass". http://www.hwglass.co.uk/glass-stockiest.html This has been either sandblasted or etched by the factory. Might do just the job without messing around with trying to sandpaper it. Or take it to a local sandblaster. I really like the idea of direct to the glass because I am now really fed up with taping all the time. Makes setting the height with any prescision impossible too. C. Share this post Link to post Share on other sites
fuchs 0 Report post Posted October 2, 2012 in Printing Directly to Glass There is also this on Thingiverse: http://www.thingiverse.com/thing:24172 Share this post Link to post Share on other sites
