Posted · 15.06.00 Cura error whist loading
I installed the new Cura 15.06.00, but if I try to open the program I get an error message "Cura Error". I can only terminate the process or open the console. Have a fresh install of Yosemite 10.10.4 and this is one of the first programs I installed.
Error log from the console:
01-07-15 12:32:42,415 locationd[77]: Location icon should now be in state 'Active'
01-07-15 12:32:43,374 locationd[77]: NETWORK: requery, 0, 0, 0, 0, 17, items, fQueryRetries, 0, fLastRetryTimestamp, 457438627.0
01-07-15 12:32:44,908 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
01-07-15 12:32:46,222 locationd[77]: Location icon should now be in state 'Inactive'
01-07-15 12:32:47,041 Cura[1174]: Cura Error
01-07-15 12:32:47,042 Cura[1174]: 2015-07-01 12:32:47.040 Cura[1174:64058] Cura Error
01-07-15 12:32:52,066 Cura[1174]: Traceback (most recent call last):
01-07-15 12:32:52,066 Cura[1174]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 77, in
01-07-15 12:32:52,066 Cura[1174]: _run()
01-07-15 12:32:52,066 Cura[1174]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 62, in _run
01-07-15 12:32:52,067 Cura[1174]: exec(compile(source, path, 'exec'), globals(), globals())
01-07-15 12:32:52,067 Cura[1174]: File "/Applications/Cura.app/Contents/Resources/cura_app.py", line 8, in
01-07-15 12:32:52,067 Cura[1174]: app = cura.CuraApplication.CuraApplication.getInstance()
01-07-15 12:32:52,067 Cura[1174]: File "UM/Application.pyc", line 326, in getInstance
01-07-15 12:32:52,068 Cura[1174]: File "cura/CuraApplication.pyc", line 64, in __init__
01-07-15 12:32:52,068 Cura[1174]: File "configparser.pyc", line 937, in __getitem__
01-07-15 12:32:52,068 Cura[1174]: KeyError: 'general'
01-07-15 12:32:52,995 com.apple.WebKit.Networking[487]: tcp_connection_destination_prepare_complete 1144 connectx to 2a01:111:f406:8800::20.443@0 failed: No route to host
I also got an error while loading. I'm using Yosemite too and Cura 15.06.00.
Here's the log:
15/7/1 下午7:06:33.654 Cura[87124]: Cura Error
15/7/1 下午7:06:33.655 Cura[87124]: 2015-07-01 19:06:33.654 Cura[87124:3176673] Cura Error
15/7/1 下午7:06:35.286 osascript[87166]: Performance: Please update this scripting addition to supply a value for ThreadSafe for each event handler: "/Library/ScriptingAdditions/SIMBL.osax"
15/7/1 下午7:06:36.567 Cura[87124]: Traceback (most recent call last):
15/7/1 下午7:06:36.567 Cura[87124]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 77, in
15/7/1 下午7:06:36.568 Cura[87124]: _run()
15/7/1 下午7:06:36.568 Cura[87124]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 62, in _run
15/7/1 下午7:06:36.568 Cura[87124]: exec(compile(source, path, 'exec'), globals(), globals())
15/7/1 下午7:06:36.568 Cura[87124]: File "/Applications/Cura.app/Contents/Resources/cura_app.py", line 8, in
15/7/1 下午7:06:36.568 Cura[87124]: app = cura.CuraApplication.CuraApplication.getInstance()
15/7/1 下午7:06:36.568 Cura[87124]: File "UM/Application.pyc", line 326, in getInstance
15/7/1 下午7:06:36.568 Cura[87124]: File "cura/CuraApplication.pyc", line 64, in __init__
15/7/1 下午7:06:36.568 Cura[87124]: File "configparser.pyc", line 937, in __getitem__
15/7/1 下午7:06:36.568 Cura[87124]: KeyError: 'general'
15/7/1 下午7:06:36.668 Console[87169]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
    Posted (edited) · 15.06.00 Cura error whist loading
    Check out the new download. They hotfixed some stuff related to Cura not starting on windows. They are currently fixing Linux and Mac :) Keep an eye out on the download page
    same same.
    01/07/2015 16:10:12.073 Cura[1600]: Cura Error
    01/07/2015 16:10:12.073 Cura[1600]: 2015-07-01 16:10:12.072 Cura[1600:90249] Cura Error
    01/07/2015 16:10:13.911 Cura[1600]: Traceback (most recent call last):
    01/07/2015 16:10:13.912 Cura[1600]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 77, in
    01/07/2015 16:10:13.912 Cura[1600]: _run()
    01/07/2015 16:10:13.912 Cura[1600]: File "/Applications/Cura.app/Contents/Resources/__boot__.py", line 62, in _run
    01/07/2015 16:10:13.912 Cura[1600]: exec(compile(source, path, 'exec'), globals(), globals())
    01/07/2015 16:10:13.912 Cura[1600]: File "/Applications/Cura.app/Contents/Resources/cura_app.py", line 8, in
    01/07/2015 16:10:13.912 Cura[1600]: app = cura.CuraApplication.CuraApplication.getInstance()
    01/07/2015 16:10:13.912 Cura[1600]: File "UM/Application.pyc", line 326, in getInstance
    01/07/2015 16:10:13.913 Cura[1600]: File "cura/CuraApplication.pyc", line 64, in __init__
    01/07/2015 16:10:13.913 Cura[1600]: File "configparser.pyc", line 937, in __getitem__
    01/07/2015 16:10:13.913 Cura[1600]: KeyError: 'general'
    Time to play with the new version :)
    Do you have a "Print to USB" button available on OS X version? I only have "Save to Disk".
    Issue posted on github
    If it should be there by default, it's missing. But maybe it only works when the USB is connected? Just like with a SD-card. It only shows the option to save to the SD when it's available.
    My first experience with the new Cura: appears to be slower than previous version, missing the layer number/height indicator when going through the layers, the process with the option 'wire printing' selected stops just before the end of the bar (and does not want to finish to process a wire printed Marvin).
    However, I move these comments to another topic.
    It is. I just wanted confirmation that I wasn't the only one with no Print button.
    The USB print button only maaagically apears when it finds a printer. This is changed from the old cura where it would always show a print button when something that resembled a printer connected (even an Arduino board). The new Cura first validates if it actually speaks g-code before showing it as an option.
    Hey, I'm running MacOS 10.8.5 and tried Cura 15.06.01 and get dumped with an error:
    7/2/15 2:42:52.960 PM Cura[5336]: Cura Error
    7/2/15 2:42:55.782 PM Cura[5336]: Traceback (most recent call last):
    7/2/15 2:42:55.782 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/__boot__.py", line 77, in
    7/2/15 2:42:55.783 PM Cura[5336]: _run()
    7/2/15 2:42:55.783 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/__boot__.py", line 62, in _run
    7/2/15 2:42:55.783 PM Cura[5336]: exec(compile(source, path, 'exec'), globals(), globals())
    7/2/15 2:42:55.783 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/cura_app.py", line 6, in
    7/2/15 2:42:55.783 PM Cura[5336]: import cura.CuraApplication
    7/2/15 2:42:55.784 PM Cura[5336]: File "cura/CuraApplication.pyc", line 4, in
    7/2/15 2:42:55.784 PM Cura[5336]: File "UM/Qt/QtApplication.pyc", line 15, in
    7/2/15 2:42:55.784 PM Cura[5336]: File "UM/Application.pyc", line 4, in
    7/2/15 2:42:55.784 PM Cura[5336]: File "UM/Controller.pyc", line 6, in
    7/2/15 2:42:55.785 PM Cura[5336]: File "UM/Tool.pyc", line 7, in
    7/2/15 2:42:55.785 PM Cura[5336]: File "UM/Scene/Selection.pyc", line 5, in
    7/2/15 2:42:55.785 PM Cura[5336]: File "UM/Math/Vector.pyc", line 4, in
    7/2/15 2:42:55.785 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/__init__.py", line 187, in
    7/2/15 2:42:55.786 PM Cura[5336]: from . import fft
    7/2/15 2:42:55.786 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/fft/__init__.py", line 6, in
    7/2/15 2:42:55.786 PM Cura[5336]: from .fftpack import *
    7/2/15 2:42:55.786 PM Cura[5336]: File "/Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack.py", line 40, in
    7/2/15 2:42:55.786 PM Cura[5336]: from . import fftpack_lite as fftpack
    7/2/15 2:42:55.787 PM Cura[5336]: ImportError: dlopen(/Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so, 2): Symbol not found: ___sincos_stret
    7/2/15 2:42:55.787 PM Cura[5336]: Referenced from: /Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so
    7/2/15 2:42:55.787 PM Cura[5336]: Expected in: /usr/lib/libSystem.B.dylib
    7/2/15 2:42:55.787 PM Cura[5336]: in /Applications/Cura/Cura.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so
    7/2/15 2:42:55.832 PM com.apple.launchd.peruser.311931414[417]: ([0x0-0x94094].org.pythonmac.unspecified.Cura[5336]) Exited with code: 255
    I'm in no way a software creator. I can double click like a demon, though.
    Clear Dark Skies,
    Bird
    Ugh. This is why developers hate mac. Could you also post the log file?
    Hey nallath,
    Is this a log file? From Console I cleared the display and then tried to open the new Cura and got this:
    Marker - Jul 6, 2015 4:05:15 PM
    Jul 6 16:05:40 LASLA40027341 Cura[11809]: Cura Error
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: Traceback (most recent call last):
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/__boot__.py", line 77, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: _run()
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/__boot__.py", line 62, in _run
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: exec(compile(source, path, 'exec'), globals(), globals())
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/cura_app.py", line 6, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: import cura.CuraApplication
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "cura/CuraApplication.pyc", line 4, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Qt/QtApplication.pyc", line 15, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Application.pyc", line 4, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Controller.pyc", line 6, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Tool.pyc", line 7, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Scene/Selection.pyc", line 5, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "UM/Math/Vector.pyc", line 4, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/__init__.py", line 187, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: from . import fft
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/fft/__init__.py", line 6, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: from .fftpack import *
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: File "/Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack.py", line 40, in
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: from . import fftpack_lite as fftpack
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: ImportError: dlopen(/Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so, 2): Symbol not found: ___sincos_stret
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: Referenced from: /Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: Expected in: /usr/lib/libSystem.B.dylib
    Jul 6 16:05:47 LASLA40027341 Cura[11809]: in /Applications/Cura/Cura_new_dead.app/Contents/Resources/lib/python3.4/numpy/fft/fftpack_lite.so
    Jul 6 16:05:47 LASLA40027341 com.apple.launchd.peruser.311931414[417] ([0x0-0x1ab1ab].org.pythonmac.unspecified.Cura[11809]): Exited with code: 255
    Is this what you were looking for?
    Clear Dark Skies,
    Bird
    @Bird This is not the logfile, but helpfull none the less. The logfile is an actual file (with .log extention)
    Hey nallath,
    I'm clueless. I'll just run the older version until a software person has issues with the new version and can properly communicate with you.
    Clear Dark Skies,
    Bird
