reduce current motor
krane
Posted · reduce current motor
Hey,
on my UM2, the temperature of X,Y motors is too hot (i can't let my finger on it 1s), my printer is clean and i put some oil. I intent to reduce en the firmwire the current motor max from 1300 to 1200 mA but i didn't find the line in the files...i just find in configuration_adv.h :
// actual motor currents in Amps, need as many here as DIGIPOT_I2C_NUM_CHANNELS
#define DIGIPOT_I2C_MOTOR_CURRENTS {1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0}
can someboby tell me how i can reduce the current motor max en Marlin (UM2) ?
thank you so much !
    Your motors are probably fine. I think they can be up to 80C which is very hot. It's normal for them to be too hot to touch.
    You can reduce the current with a simple gcode but if you do you will need to also lower the acceleration and jerk settings. I don't recomment you mess with it.
    The new start code in the default UM2 profile provided in the latest version 3 of simplify3D sets the extruder motor current to 1400, any thoughts on that ?
    Stepper motors do run hot. I would avoid dropping the current, there is a danger of them missing steps. I was surprised that UM2 allows changes to the currents, you could easily get very unexpected results.
    My motors get really hot especially when printing ABS, because I keep the whole thing toasty by blocking all the big holes. The longest ABS print I have done is around 22 hours I think, no problems to report. So don't worry.
    Another thing is the UM2 is really superbly balanced; avoid messing with anything other than what's available via the UI. Even then, take cautious steps. I have reset to factory defaults on more than one occasion when my enthusiasm outpaced my knowledge :-)
    Ok, thanks to all of you.
    I built a reprap BCN3D+ last week and fixing the pololu i was able to use the printer for a long time without heating that much the motors. So i get surprise to see how hot are the motors of my UM2 during a print in ABS or PLA.
    really kind of you to respond with details
