It was dropped for the moment as its implementation was horrible. If your standard frame is rotated by 90 degrees it's probably better not to use the lay flat in the first place but to simply rotate the object by the required amount.
I've figured how I can specify a CSYS to export from, but with some complex parts it's easier to reorient in Cura and see how it changes the slicing. It's a tool I used a lot, and am looking forward to getting it back.
Thanks.
nallath 1,065
