Help with installing IRobertI's feeder
Posted · Help with installing IRobertI's feeder
I have printed IRobertI's feeder for the UM2, bought the necessary parts, but the thing that had me scratching my head was that if I remove the four screws holding the default feeder in place, won't the motor drop down? If yes, how does one replace the feeder?
    Stick you finger in the hole where the braided cable comes out to hold it up. Then when the feeder is off, pull the knurled drive and insert a screw to hold it in place till you are ready to install the next bit.
    Tuto by @didierklein
    link
    I agree with neotko, just remove the white cover plate and save yourself any headache. Just make sure you don't pinch any wires when you re-attach the motor.
    Fantastic stuff! Much appreciated.
    Well, I followed all your helpful advice and it turned out that replacing the feeder was really very simple. Far simple than I thought it would be, and I should have done it ages ago since it if far better than the stock feeder.
    I was struggling with nylon (Taulman Bridge) and Robert's feeder makes it a doddle. Also the quick release is brilliant.
    So, thank you Robert. And if you are reading this and wonder if you should go ahead and change your stock feeder, then let me encourage you to do so.
    I fail to see why Ultimaker have not incorporated your ideas into their feeder, it is that good!
