bob-hepple 59
Yes thought the same but not sure if Layburn was trying to stabilise the temperature. Sure gonna find out though. But I think it will still be better than the stock shroud.
I have installed a similar fan shroud (just the back is slightly different.
The closed bottom is better to avoid a sudden drop in temperature when the fans are activated.
I like the design of this one, mine is printed in colorfabb xt with no kapton and they don't melt
I have been using it for a long time even printing with XT with no deformation of the bottom. Just a little on the left side. I printed mine with XT-CF20. The bottom is closed to stop the temp error and some have even asked for a more closed in design then the one pictured.
Personally I'm not a fan of printed shrouds so I'm in the process of getting metal ones made. It's just taking a bit longer as I have been busy working on other things.
If you get them made in metal how would this effect the Olson Block I thought I saw something about the std shroud drawing heat away from the heater block.
I'd also open up the hole for the nozzle a bit more The hex wrench wouldn't fit through the hole I reamed it out, we are only talking about 1mm on the Diameter.
I'd would also be interested in trying a metal version if ordering multiples would be cheaper I thought of having one sintered
Yes the standard block does draw heat away if it touches. My fan shroud is designed with the Olsson block in mind so it doesnt touch.
Noted about the hole. Ill fix that.
Here is a pic of a flow test done on my shroud. Thought you may be interested. The Original UM shrouds velocity is about 0.6m/s
what software does that flow simulation?
I actually didn't ask
Someone offered to do it for me.
I don't get it ... the nozzle is sticking out underneath, so why would the hex wrench need to fit through? I never noticed this as a problem (using the standard metal UM2 shroud)
My shrouds sits lower then the metal one so it's the same height as when using the original nozzle.
@Labern any updates on the metal version of the fan shroud for our UM2?
ultiarjan 1,223
Like it all.... except I really don't understand why this fan shroud is completely closed at the bottom, I would expect less problems with deforming if the bottom was open ?
Anybody using this thing for a longer time ?
