my cup keeps getting closed at top
kerberg
Posted · my cup keeps getting closed at top
Post photos. I don't know if you modeled the cup as a cylinder and unchecked "top layer" or if you are modeling the width of the walls of the cup carefully? The first method works really well - espeically with a larger nozzle size.
Most likely you are doing #2 and need to uncheck all the "fix horrible" boxes as stated above.
    thanks- never knew about the fix horrible boxes... will try that.
