Hello Didier from Belgium!
Here are my settings :
PLA
Printbed 60°
Printing temp 210°
Flow 100%
Layer height 0,08mm
Shell thinkness 0.8mm
Enable retraction : yes
Printspeed : 30mm/s
Travelspeed : 120mm/s
Printspeed botom layer : 20mm/s
Infill 15%
No support and no platform adhesion
Extra question: Is there a way to view the settings of a gcode file used in Cura?
About the blue tape... that's what they advised me at the shop Trideus...
DidierKlein 730
Hi there fellow Belgian!
Can you please share your print settings?
Why do you use blue tape on the UM2? The heated bed should do the trick
On the second picture it looks to me like you have underextrusion but it's hard to tell, and many things can be the cause
