Have tried the stepper driver in the x axis today and its fine, if i put the x axis driver in the extruder still nothing , so its not the driver (was my first assumption / thought too , know how easy it is to kill things) as i said tested the driver and the motor and they are all functioning perfectly on the other axis is just when plugged into the actual extruder section of the pcb.
Dim3nsioneer 559
Sorry, I didn't read your OP properly obviously... You don't happen to have a spare Arduino, do you?
You may try to put the stepper driver into the second extruder socket and change the routing in pins.h in Marlin.
Looking into the rerouting of the pins.h right now , and yes i do happen to have a spare Arduino (or 3) lying around lol will have to see if my Mega2560 is in use though
Ok so tried changing the pins to 48,47,49 in marlin and uploaded it to my spare mega and still no joy (even worse now i definitely have one burnt out driver due to wrong direction) so i really don't know what it is, unless its a resistor or something that serves those 2 sets of connections only thats gone.
This sounds similar to the problem I've been having with my UMO+:
Does that sound like a similar problem to yours? So far I haven't found any solution, but maybe something similar happened to both of us to make the problem occur?
Your problem sounds very similar indeed, did some more experimenting last night , checked as many components as i could , including the caps under the drivers, even have the schematic sat on screen and there doesn't seem to be anything that just goes to the extruder ports and not the others aswell, really hope someone with a working knowledge of the electronics finds this soon, because otherwise i'm going to have to go down the route of a cheap chinese copy of the board due to real lack of funds, i really don't want to do that i'd rather fix this board if possible.
Anyone got any ideas at all about this issue ?
Yes.
The feeder will not turn unless the head is > 170C. You can enable "cold extrusions" with this gcode or you can heat the nozzle:
allow cold extrudes
M302
Just put that gcode in something and print it or send that through pronterface. Then the extruder will start turning.
Thanks gr5 will give that a go once i'm back next to the printer, guess that got added into the firmware while mine was in storage lol
*EDIT* gr5 you beautiful human being, thank you so much for that info , turns out that was indeed the issue, and there is nothing wrong with the extruder at all , many many thanks for saving me a lot of time and possibly money trying to get it working
2
- 1 year later...
Yes.
allow cold extrudes
M302
gr5 you are indeed awesome! Same problem, same solution. Well done, Sir!
Dim3nsioneer 559
Exchange the stepper driver. It's gone (I'm 99% sure as I also happened to kill some UM original drivers like that).
