Well that depends. Yes, you can increase speed to 200%, or 1000% if you feel like it. The question is if the printer will be able to comply without the print failing. That all depends on what speed you set when you sliced the object. 10mm3/s (nozzle size*speed*layerheight = 0.4*X*Y) is pretty much the absolute maximum you can expect, on a sunny day with the wind in your back.
If you tell us the settings you used when you sliced the vase it will be easier for us to help you.
i didn't understand that
i am new at this , i just downloaded it and put it in cure then put it to the maximum quality then i save it to the sd card and print the design with it .
after 14 or 15 hours i thought that i can make it faster
then i post this .
till now it seems to be ok ( i guess )
IRobertI 521
