Hi and thank you for the fast eesponse!
The pegs and the cycles are different sufaces I want to generate on a smooth base. In other words they do not stick togather. I wonder whether the UM 2 can print those...
In other words one object I want to print has the described pegs. The other object hast the described circles.
SandervG 1,499
Hi Agis,
Could you be a little bit clearer about what you are trying to do?
If it is a flat surface you could manually alter the gcode by having it start not at 0, but at a given height.
Wouldn't it be easier to glue the 2 parts together?
