Hi Folks,
A last report about the testing after this modification.
When I loaded a roll of black PLA (Verbatim), the usual thing happen and it started to extrude filament out of the nozzle, then I heard the feeder stepper started to skip. As I watch this, it seemed to have a little less flow than before and the feeder act as it was compressing a "strong spring"! Every time it skipped it moved about 90 deg. back, then started to compress again. I was wondering if there was any remains/gums etc. inside the nozzle, so I did a few "atomic Bob". To my surprise the filament broke of right at the top of the Teflon coupler, I've had to reload manually and squeeze out a little PLA. After this, let the temp go down to 60 deg. Celsius, then set it to 90 deg. C and when at 90 deg. pull..
Then it come out "almost as" normal, but -just about where the Teflon coupler is insulating the heat block from the upper "cold part" of the extruder there was a circle/section of the filament with less diameter than the filament diameter(2.95 mm).
This set me somehow out.. After some thickening, I realized that I've lifted the heat block a little up. Aha., so I reduced the gap back to about 0.8 mm and made another test, bingo...
The little fan improved the cooling so much that is also cooled more of the upper part of the heat block. So, the faster the filament was tried to be feeded through that passage the more energy was needed to melt the filament.
So now I'll know how important the adjustment of the height of the Teflon coupler is.
You're actually adjusting the width/sharpness of the hot/cold zone for the hot end.
As a final test I printed the "extruder feed test", started with the temperature of 205 deg. Celsius and monitored the temperature until finish. When the temp descended one deg. I rolled it up one deg. more and so on. It finished at 207 deg, Celsius with no issue..
All in all, I'm very pleased with this result.
Thanks.
Torgeir.
Top Posters In This Topic
6
7
9
6
Popular Days
Oct 15
7
Oct 26
5
Jan 6
4
Oct 27
4
eldrick 6 posts
izzy 7 posts
Jamezracer 9 posts
Torgeir 6 posts
Popular Days
Oct 15 2015
Oct 26 2015
Jan 6 2016
Oct 27 2015
Posted Images
Torgeir 205
Hi Folks,
As I've modified my spare extruder, now it's time to do the extruder that's removed from my printer.
First, here is a picture of both extruders. The right one is the spare one, still have some issues to be fixed before I can use it on my printer..
You'll see the Alum tape I'm using to have the pressure center at the nozzle. Also you'll see how the wiring from the heater block shadow the inlet for the cooling fan.
This next picture is after this modification on the extruder normally installed on the printer.
First, this modification on the used heat block was not an easy task. So if you're going to do this modification you need to have some spare part aviable in case something break, because here it is very easy to breake the wiring esp. the one for the heater element. So do not rebend the wires, they should stay in same position as it have under the whole modification!
I've had to power up the heat element in order to unscrew the adjustment screw for the Teflon coupler, as there was a sign of black plastic at the connection to the heat block. I'll think heating also is a good thing to do before trying to remove the heater element.
As I added the copper paste into the heat block attatcment hole's for both the heat element and the PT100 from before started using it, there was a minor task to remove them.
So, now you're warned about the problem that's may occur if you like to do this modification.
OK., here is a picture of the split-ted extruder, just before I connected the heat element to an external power supply using 12 VDC only. Using this voltage brought the temperature up to around 130 deg. Celsius.
The gap between the Teflon coupler and the adjustment nut is a little bit lo, only 1 mm..
Heating up to 130 deg. C.
Here is the hot block attached to my "mini" vice. This block have more than 300 hour in printing, well, not much but still nice. You'll see I'm using the copper paste at the thread here as well.
I've had to clean up the threads with this tool, no need for adapter here, only bare hands! Be very careful if you need to clean away plastic using this method.
Here is the "essence" of this modification, the printed duct from James and related parts.
I've somehow come to the limit of how much I could upload, so next time I'll compress the pictures.
Just one more thing to mention is that I've had to make a cutout where the wiring going into
the extruder plastic housing, the same way the Chinese did it on the spare extruder housing from China.
Anyway, this is the way I did this modification.
Thanks.
Torgeir.
