The only way to make it cheaper it's to really change most of the stuff. For example, instead of the um2 board, a rambo board. Or instead of the umo head a e3d lite for 1.75mm (good for 240C print). Most of the components you can ask Ultimaker sales (support.ultimaker.com) and they will give you a quotation. I have buy to them um2 x/y/z motors, led strips, a whole wood frame laser cut, etc. their quality it's great ofc, but isn't 'cheap'. Also buying on aliexpress, if you know what you buy, can work, but it's a 50/50 chance.
Check my experience about going aliexpress on technical stuff:
nallath 1,101
This sounds like a customer that wants everything; It needs to be cheap and perfect. You simply can't have both.
Judging from all the issues that you have it seems like that it's way more expensive to re-source the UMO+ compared to just buying the kit and assembling that one. Is there a specific reason why you're resourcing everything (As the 'same part' from a different company isn't always the 'same part', so expect issues here)
