The gcode that came on the card has all those settings so just save that g code or keep in on your card. You don't need to load it into cura to print it. Just select it from the print menu on the printer.
The only thing is the machine settings like temps and acceleration speeds if adjusted will need to be put back to default. You could make a material profile the same as the default PLA and name it test or something if you want to make changes to the Pla profile.
gr5 1,967
gcode files store all the settings used to create the gcode file - at the end in a binary format. In cura you can select "file" "open profile from gcode" and that will load all the settings from that gcode file into cura and then you can go through them all and look at them or save them out "save profile...".
