No heat? At first I was going to say it's probably touching the fan shroud but if you get no heat then the heater wire came loose or got damaged. Hopefully the wire just fell out underneath the printer. You could for example measure the resistance of the heater from underneath also - it should be about 23 ohms for a 25W heater although in practice they are often lower wattage. Anyway if it measures infinite ohms then it's probably destroyed (sorry). In USA I sell heaters at a reasonable price at my store here or you can get them at fbrc8.com:
gr5.org/store
Thanks for the reply. I tested the heater, and I got nothing. It is possible that the wires were damaged when I was pulling the thermo couple through. Looks like I need a new one.
gr5 2,210
gr5.org/store
