Does this do the calculations based on the extruder hole diameter and is that hardwired to .4mm or can it be adjusted like say changing the min thread thickenss?
Different nozzle sizes have different usable min/max thread widths, which you (or, rather, "I" for now) can just feed to the program but nozzle size doesn't really have as much impact on the extruder speeds as you might think so no, the code doesn't factor that in.
It's really all about volume - matching the volume of threads in the print with the correct amount of filament feedstock..
With people reporting more clogged nozzles I'm thinking I may try to cut some parts to allow for a makergear hot end, and in that case, would probably like to set it up with two heads of differing sizes. Probably have to just switch the wiring back and forth to use one or the other until more support for multiple heads comes in, but I'd love for both sizes to work in Netfabb.
I'm suspicious about the clogged nozzle stuff - I don't think anybody here has ever actually clogged a nozzle up unless they've run things waaaay too hot and baked all the bendy out of the filament. Most of the problems seem related to too much heat traveling up the hot end and forming a plug at the end of the bowden cable. To actually physically clog a nozzle, you need particules far bigger than dust or hair..
Top Posters In This Topic
35
10
6
6
Popular Days
Jan 2
9
Jan 8
8
Jan 3
6
Dec 31
5
ddurant 35 posts
joergen 10 posts
cyclone 6 posts
rencio7 6 posts
Popular Days
Jan 2 2012
Jan 8 2012
Jan 3 2012
Dec 31 2011
cyclone 0
-b
