Your question somehow suggests you already did the appropriate calculation and saw it will leave the elastic range?
If you are looking for an official answer, you may want to submit a support ticket to Ultimaker or to your local distributor.
The other question is why someone would like to print a solid block of ABS. I would expect any reasonable model not having 100% infill of that volume. I might be wrong.
I did a calculation, it gave me a deformation of 3mm at the end of the plate. Although i am unsure if that is appropriate/ legit. Would like to know if that is right. Rather, I am more interested in knowing the maximum weight it can handle..
THanks..
Dim3nsioneer 559
Edited by GuestLink to post
