just a thought, you may try increasing the materiel flow rate by 20-25% too
But if he do that the output will look more like a 0.5...
Imo you can print lower size with the nozzles, specially if you set a lower speed (because of the jerk on curves). I haven't try this on cura, but on s3d I print almost all day with a different desired output of what my nozzle it's and it works great. Of from 0.5 to 0.4 it's a big gap, but doable. I would stay on 0.45 to avoid ugly circles. Also, I would lower teh acceleration and a bit of jerk.
I print this for my shop and the letters are simulating a 0.31 and 0.36 nozzle size. I play with it to be able to print what I need, not what can be printed by default.
1
ultiarjan 1,220
Basically lines on a surface will be closer together ( vs if you set nozzle to .5) And cura will extrude the volume as if it's a .4 nozzle. Just try it, think the results wil be ok.
skinny-kid 64
Thanks for the input Ultiarjan.
Going to give it a go and see how the print turns out.
SK
