I guess the final question is ... is it worth the additional $500?
What criteria would you use to determine which one?
If you had a project that can be built in the Extended+, but must be broken up for the UM2+, is the work required to break it up that time consuming as to justify the difference?
Since I've never owned a 3D printer I'm trying to get a handle on this.
thanks,
-gary
IRobertI 473
The only difference is the height.
