If you pull the SD card out it will stop - the computer in the printer is an arduino and only stores about 12 commands ahead.
For the layer height question - it will do 0.9 layer height. If bottom layer is .3mm (default) then that's a total of 7 layers (a .3 thick layer and 6 .3 thick layers). For this question you can ask Cura instead of humans and just look at it in layer view.
To get extra smooth bottoms some people found it helps to print a thinner bottom layer - say .2mm or even .1mm. Also if you spread glue on the glass, you should use a wet tissue to spread the glue - if the glue is lumpy the bottom of the part will also be lumpy. If you print a bottom layer of .1mm then you need leveling all that muich better. Don't use the procedure but instead just adjust the 3 knobs while it's printing. Eventually you will get it perfect.
There is a "pause at Z" plugin. It's fantastic - get it. It's meant for exactly this kind of thing - changing filaments at a given layer or inserting a part. Make sure the part doesn't stick up!
If you want to do it the hard way, get tinker marlin - it's very very simple and easy to use and it gives you much more functionality including continuing a failed print, or showing the current Z position during a print. Having the Z value lets you sit by the printer until it is at the right height.
SandervG 1,521
Welcome to the forum!
Hopefully you have learned a lot, and you'll also give back some of the knowledge you have gained and will gain down the line![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
About your questions:
Can I pull the SD card out of the printer once a part has started printing?
Nope. It will stop/cancel/ruin your print.
First layer:
You probably need to reconsider your bed levelling.
Pictures are always good! If you can add a picture from your first layer we could probably give you some good pointers.
Originally, your first layer should be 0.3. It is also set so in Cura. Did you change this?
It is best to keep your top layer a multitude of your layer height.
So either go for 0.8 or 0.9
There is a Pause feature that can pause your print at Z. Check Cura plugins for this feature.
Good luck!![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
