I have a similar issue. Maybe it's the same, I believe I have found the reason for it.
My issue:
I'm printing a very small object, each layer takes not even a second (so claims Cura).
For some reason, Cura is adding code that moves the head to the side, extrudes a bit, then moves back extruding some more.
When viewing the GCode with Repetier Host, I can see the extranous head movements. They make no sense model-wise, as they're about 2 CM from the model.
I have looked at the GCode and noticed weird G0 codes - immediately before a new layer.
When I set the minimal layer time to 0, the resulting GCode contains no extra movements.
But when I set it back to 5 seconds, the extra movements/extrusions appear.
Not sure if this is intended, but it almost looks like Cura is expecting there to be a wipe tower?
I can't upload GCode files apparently, so here's snippets of the file, containing one layer each (same STL, same settings, apart from delay):
M117 Layer 56 of 58G0 X97.767 Y102.634 Z11.300;TYPE:WALL-OUTERG1 F2400 E44.00057G1 F600 X97.233 Y102.634 E44.01829G1 X97.233 Y101.365 E44.06039G1 X97.767 Y101.365 E44.07810G1 X97.767 Y102.634 E44.12021;Small layer, adding delay of 4.386900G1 F2400 E39.62021G0 F4800 X97.767 Y102.634 Z14.300G0 X117.767 Y102.634G4 P4386;LAYER:56
Edited by GuestM117 Layer 56 of 58G0 F4800 X97.767 Y102.634 Z11.300;TYPE:WALL-OUTERG1 F3000 X97.233 Y102.634 E44.01250G1 X97.233 Y101.365 E44.05460G1 X97.767 Y101.365 E44.07232G1 X97.767 Y102.634 E44.11442;LAYER:56
neotko 1,417
Check that the bowden it's really inserted on the ptfe coupler. Check the feeder to see if the filament slips inside. Check the feeder tension to see if it's too low or high and the filament slips. Clean the knurted bolt of the feeder (if it's full of material it can slip) using a metal/nylon brush. Check that there's no heat near the feeder that can make the filament losse strength and be easily crush by the feeder. Check the ptfe coupler has 1mm separation with the steel coupler. Check that the fancap isn't touching the hotend.
Make photos. Front hotend. Feeder. Atomic pulls.
