Which printer? I don't know how to do it for the um2+ but for the UM2 it's pretty easy and obvious - just loosen the set screw on the side. I think it's a 1.5mm hex.
Hi there
It is a Um2 extended
I loosened the grub screw and completely removed it, but for the life of me even with pliers I cannot remove the knurled bolt, I have tried shocking it and using penetrating spray.
Should it literally just pull off?
Thank you in advance
gr5 1,967
