there are different solutions to get this right:
•play with the cooling settings, maybe add the 'cool head lift' in the expert settings.
•print more than one using the 'print all at once' under tools.
•add support, check the layer view which the orientation suits you best, rotate the model to get the best support
•rotate your model until the top surface is horizontal and use support
pictures help to get this right!
SandervG 1,522
Hi, welcome to the forums!
Happy to hear you are happy with your Ultimaker 2+!
Could you also share a picture of your print that illustrates the difficulties you are having?
If the part that needs to be 3D Printed is too small it may be that Cura skips it but looking at your STL it doesn't appear to be the case.
Looking forward seeing a picture of your print!
