That's exactly the problem I imagined on my head with an extruder that strong... Imagine the filament it's water, and ptfe coupler, barrel, nozzle, are the pipes. If there's an error (ptfe coupler dead, nozzle not tight, any space at all) the water will leak and will find its way. With a normal extruder you would have just the extruder skipping because some part has gone cold and it can't move more. With an overpowered extruder the filament will keep pushing no water what.
So with a bondtech you really need tnmake sure everything it's on it's place or it won't stop.
1
Nicolinux 288
Holy sh****. Yep sell it as modern art - Cthulhu Edition
What's with the right side where it draws the thin filament shell? Maybe the print went well for a while and then it did not stick to the bed and the plastic accumulated at the nozzle. Or the nozzle was partially clogged and the filament curled upwards.
