Thanks guys,
I had heard that regarding layer height and refraction. It creates a better transparency is that correct? I am using the standard nozzle so .4, but I am considering doing the new upgrade which would give me larger nozzles to work with right? There seems to be a lot of buzz right now about the upgrade, but I think I will hold off a bit until I hear some reviews from the folks that have made the change. I feel like I finally have my extruder working and am weary of going back to the original looking feeder, even though it is supposed to be better.
yellowshark 153
Whether or not they are translucent enough for your purposes I do not know but the windows are using Faberdashery Crystal Clear and the "glass" balcony walls, including the curved one laying on its own, are using Faberdashery Glacial Blue.
Yes I tried t-glase too and gave up as I did not have enough time to get the settings right
gr5 2,330
I haven't tried transparent filament but the experts seem to agree you want very thick single pass walls. So a 1mm nozzle will give you much better results and do something like .4mm layer height and 1mm thick shell. This will work much better than the converse (.4mm nozzle with .1mm layer height and .8mm walls.
If you only have the .4mm nozzle to work with - well sorry. But try lying to cura and tell it you have a .6mm nozzle with .6 shell and .2 layer height. or maybe .4mm nozzle with .4 shell and .3mm layer height.
