Help us to test the Doodle3D WiFi-Box on your UM2+ and get a Doodle3D WiFi-Box for free
jeroen-somers
Posted · Help us to test the Doodle3D WiFi-Box on your UM2+ and get a Doodle3D WiFi-Box for free
Doodle3D offers a free Doodle3D WiFi-Box.
REQUIREMENTS:
You must have a original UM 2+ (no + upgrade)
You must be willing to do some test for us.
You can email to jeroen@doodle3d.com.
The first one to respond wins the Doodle3D WiFi-Box.
With kind regards,
Jeroen
    It's there something different on the um2+ boards than on the um2 boards that make's easier for the usb connection to work?
    We want to add the UM2+ to our list of compatible printers, but first we need to make sure it works without complications.
    And because we don't have a UM2+ to our disposal were asking the community to help us.
    An upgraded UM2 should be functionally identical to an UM2+ but it's probably a good idea to stick to a factory assembled machine just to avoid any user error during install causing weird results.
    Sent too ! I hope I'm not coming too late, that would be very nice to test it ! I'll compare it to my actual solution and also see if it does even get the 2+ better !
