so, before the end of the world, I figured a quick update of where things got to -
1) I can now load any .stl files, including damaged ones that meshlab won't load
2) I can slice and create support (simple only) any geometry, including inside-out, non-manifold, intersecting objects (-ve space) and all the other billions of combinations of broken geometry that seems to exist in stl files. no wonder so many slicers just barf at it.
phase 2 took somewhat longer than i expected, but I can now slice (almost correctly, see below) pretty much anything - even Ian's files!
(if you're reading this Ian - what is the difference between checoo and monboo?)
I said almost anything - there are 2 outstanding geometry errors I have no current fix for. I'm hoping they aren't very important in the real world..
1) infinitely thin faces (a face defined as being double sided has 0 thickness) - did you want these to print? or are they 'invisible' ?
2) incredibly thin triangle faces pointing along the z axis - these appear to give rounding errors when exported to stl (may also happen with a very dense mesh) which results in the surface not being watertight. this is no problem in that I can ignore it, but may occasionally give rise to miniature support structures or other anomalies as a side effect.
not too late to throw in your ideas for features - but I'd like to 'freeze' the feature list beginning of next year so the first version is well defined.
31
18
14
13
Popular Days
Nov 19
14
Jan 13
8
Jan 12
8
Dec 5
7
alaris2 31 posts
Daid 18 posts
codemaven 14 posts
msurunner 13 posts
Popular Days
Nov 19 2012
Jan 13 2013
Jan 12 2013
Dec 5 2012
codemaven 0
For Fun![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
I bought it because I don't like upgrading every year... I could afford it so I decided to buy top-of-the-line everything... Including a custom overclocked CPU and watercooling. I mostly only use it for development and slicing for my printer... and email![;)](//content.invisioncic.com/ultimake/emoticons/5a33abe00be82_1f609copy.png)
Cheers,
Troy.
