cloakfiend 990
Note that using the TFM with the spring on the UM2 can be problematic. In some cases the pressure from the spring is not enough to keep it pressed down.
What difference does the material of the PFTE make on spring pressure? Ive had the spring move up before due to hydraulic pressure even with the old pftes, and really it doesnt make much difference apart from pushing too hard during atomic pulls, it otherwise didnt effect the quality of my prints at all.
gr5 1,843
I'm 90% sure they are the same one. I have the upgrade kits and some recent PTFE parts. Note that roughly January 2016 they started shipping newer PTFE parts made out of a much higher temp PTFE (same material as the ones from 3dsolex I think). You can tell which is which because the newer ones are more transluscent (you can see through them so if you put them on a dark table they are darker).
IRobertI 497
There are two versions (three if you count the first one from years ago that looks very similar to the newest), the old one that looks like chalk in colour that is used on UM2s and the new one that is more translucent (TFM) that is used on the UM2+.
@gr5 it sounds strange that you've received TFM parts if you've ordered PTFEs. That shouldn't happen I don't think, they have different part numbers and in our last batch of spare parts (last week) we got both types.
