cloakfiend 990
Thanks i forgot about that. Ideally id like to save it filling in the entire bottom but .3 is better than nothing. Ill give 0.06 a go.
If you're willing to give new cura a go (which it doesn't sound like you are ), it gives you the option to set the top and bottom thicknesses separately (after toggling the visibility of that setting in... settings). So you could set the bottom to 0 and only get the infill pattern instead of a solid sheet.
Oh, robert it sounds tempting... I may try. Ill give it a go it cant hurt. I hope its as good as cura 15.04.02 in terms of surface quality. It will save me a ton of filament. A quick question, but if i put it to zero and zero infill, it will be hollow right? If i use support does it count inside or not?
Which version number is the one you would recommend? Just in case i get a different one by mistake?
Edited by GuestCorrect, it will become hollow. The support will act as if there was a bottom layer, I think.
The latest one is available here:
https://ultimaker.com/en/products/cura-software
There's a small beta link underneath the big blue button.
should i click on the beta or the main one?
The 2.1 Beta
the initial splash appeared cut halfway off my screen instead of the centre which was annoying as it meant i could only see half the window, but i gathered it was asking me which printer to select, even though the um2 was not visible due to it being cut off the screen.
Labern 772
You can adjust the Initial layer setting. It's normally set to 0.3mm and as long as your bed is leveled good then you can reduce this down to 0.1 or even slightly lower. I have successfully set it to 0.06 before but this was onto blue tape.
You can also turn the skirt off or reduce the skirt distance if your worried about wasting filament.
