What IRobertI said - listen to him!
I've repaired many bowdens. I sell the clips alone if yours is broken. They are pocket change: http://gr5.org/store/
IRobertI 497
Remove the bowden and collet. Look inside the collet, do you see the small metal blades in there? Are they clogged by remnants of the bowden? Try cleaning them with a needle or something to remove the plastic so that they can bite into the bowden properly again.
Cut off 1cm of the bowden tube to give the collet a fresh new area to grip. Make sure you cut it off as straight as you possibly can.
