fbrc8-erin 267
Hi, Steve,
Have you checked your heated bed plate and electronics board to make sure the heater wires are fully inserted, and that the temperature sensor is plugged all the way into TEMP3?
Do any error messages appear?
Has anything been disassembled recently?
Chaos_Lord 0
I did some work meanwhile. The Bed is heating up as it schould. As soon as the temperatur is reached it turns out . The tem-Sensors stays at the temperatur he reached for a very long time. Example. I head up the table to 70 Degree. When i put my hand on it it is very hot. Now i wait for 20 min. the bed is could already but the sensor still says 60 degree?
Nozzel Temp is 27 Degree
