Thanks for the reply-
Yes I am using the same filament before and after the upgrade , I have been using 73 deg C bed temperature, and a thin film of glue stick on the glass spread around with a damp cloth. I am using the reverse side of the glass plate as I have slivers of glass missing from previous prints on the side I was using before the upgrade.
I wonder if there could be something loose that is giving an inconsistent Z height as it was working fine yesterday and yet today the same print will not stick.
I did notice that the Calibration card that came with the Upgrade kit is slightly thicker than the standard printer paper I normally use (0.15mm as opposed to 0.1mm) Changing from using the card to normal paper has produced the best results so far but for whatever reason is now not working.
I will try the 0.4mm nozzle and see what happens.
gr5 2,071
So... "before the upgrade using PET". And after the upgrade also?
Sounds like you changed 2 things - upgraded to "plus" and changed the nozzle to .25. I would switch to .4mm nozzle just to see if that is related. Other than that the only thing related to the upgrade would be your leveling position.
Leveling makes a HUGE difference to how well parts stick to the glass. If you raise the glass just a little bit (rotate all 3 screws CCW by 1/4 turn) it might make a huge difference. Also keep the glass clean - maybe you got some oil on it from you hands. With PET most people have the problem that it sticks so well that tiny slivers of glass come off with the print. That's if you use PVA glue also (like hairspray, gluestick, wood glue).
What temp is your bed? You want it around the glass temp of PET which I believe is around 90C maybe? 100C? I don't remember.
