Try printing much slower. I think it's the fact that it stops and has nothing to do with the .5mm move nor the retraction. I've seen those bumps and slowing to down to 35mm/sec or even 25mm/sec makes a huge difference. Usually I can make them disappear completely.
The funny bumps disappeared with Cura 2.1.1 beta (when I got it to work). And from your suggestion, I notices the print speeds were much slower for the outer shell speeds in particular. (30mm/s)
So I copied all those setting from Cura 2.1.1 to Cura 15.04.4 and did another test print. No Joy. Still lumpy and in the exact same spots. :(
So I'm still stuck with the lumps on the only version that works with my printer and no idea how to set up the json files to get my JG Aurora A3 configured properly on Cura 2.1.1
I think I'll go eat some worms.
Edited by Guestwrong version number
Dear Dahai 8,
Depending on your original *.stl model, it can be caused by several reasons;
When your model has a shell itself, it can be that the shell is slightly thinner than your given shellsize in Cura, or nozzlesize. Adjusting either your original shell or given shell/nozzle size in Cura could make a difference. In this case, you could change the flowrate a bit, while printing.
If you print with an infill, bumps could also be caused by a retractionmoment. In expertsettings you could go for the option; "infill prints after perimeters". I think it is called "infill before walls" in the Beta version 2.1
Finally it could be caused by the retraction setting, you could play with that a bit.
At this moment I want a lot of bumps in my print, so far a came to this conclusions.
Nozzle size is .4mm and wall is 2mm thick. I've tried shell thickness of .8 and 1.2 with 15% and 100% infill. No Joy.
I did play around with lots of different retractions, even disabled retractions. Still no joy and still bumps where the head rapid-moved from one area to the next.
I will try "Infill Prints after perimeters" that would make the rapid head moves from one side to the other happen within the walls and may just work!
I'll let you know.
Thanks!
Some times I noticed that the legacy cura is a bit "bitchy" on some parts where the wall is whole-number from the nozzle size. In this cases helped me either to make the wall a tiny bit larger (e.g. 2.01mm) or "fake" the nozzle size (e.g. 0.39mm) ...
Dear Dahai 8,
And? Did the "Infill Prints after perimeters" made any difference?
Kind regards,
Minke
Yipes!
Sorry. I got on another project and totally forgot!
YES! And THANK YOU!
The movement now happens inside the walls and is not reflected on the surface.
DaHai8 73
OK, I have tried different hot-end temperatures: 190 - 215 in 5c increments. No Joy.
I have tried different retraction speeds and lengths. No Joy
I tried disabling retraction altogether. No Joy
I am now trying the extreme change of a whole different slicer: Cura 2.1.1
Yipes! It is a whole different slicer. It took me a couple hours just to figure out how to set it up and create a new printer profile (since my Aurora A3 doesn't match any existing profiles). But I do like it!
Fingers crossed.
