We had to rush the materials in for the 2.1 release. As a result, it's far from perfect!
The next releases will have a system for this, along with a large number of other improvements.
Ah, I see. Okay, so for now, would you suggest I just use the PLA (or ABS) setting for all weird materials? I.e. is there a current setting I and get by with for now? Or should I go back to the old Cura for now?
Thanks very much!
nallath 1,123
