What I do to take it out its:
Assemble the nozzle while hot like if you where going to use it. Then unscrew the peek. It comes out very easy if the nozzle pressure it's 'on'. I broke 4 barrels or more before finding out
Upss I get it. You can't do that... Then do what gr5 says indeed.
gr5 2,243
Try freeze spray on the metal only for a long 20 seconds and then grip with rubber sheet or rubber gloves. The cold will make the metal shrink faster than the PEEK part.
